48 v shark pack not charging... Should I try to reset the BMS?
    It began last week when I went to charge my battery. The spark when i plugged the battery pack into my disconnected charger was larger than normal.
    After that I reconnected everything to charge the pack and could not get the charger to charge it (the light stayed green on the charger). I tried my second charger with the same results.
    I read through the battery FAQ and saw the portion about resetting the BMS. I have not attempted this because the lights on my battery pack are still working.
    So I wanted to ask if I should attempt to reset the pack and if that is not an option what should I do?
    I have this same issue so what was the fix?
