Will the 48 volt LUNA battery to overvolt the FLX bikes fit the Surface Boar 604?
    I'm most concerned about whether it will physically fit into the frame just as the 36 volt battery that comes with the Surface Boar 604 does. It appears to be roughly the same dimensions with the same type of connections. If it fits, but the stock controller and motor are incompatible, I can always swap those out. But, at least I could still use the frame.
