52 volt batteries, how to determine capacity when display is set to voltage
    This topic is for customers which purchase one of our color displays that can be set to voltage
    Lithium batteries discharge slightly differently to how the fuel tank gauge in combustion engine vehicles operate. This topic is to help you to understand the approximate % left. We recommend setting the display to volts and not percentage as it's more accurate.
    A fully charged battery (100%) is approximately 58 volts. The below percentages are approximate only, as this will vary due to differing discharge rates.
    This is approximate only:
    90% - 56 volts
    80% - 55 volts
    50% - 51 volts
    30% - 48 volts
    20% - 47 volts
    10% - 46 volts
    0% - 40 volts
    https://electricbike.com/forum/filedata/fetch?id=46252&d=1521089057
    We do not recommend discharging below 46 volts. This is especially so during the first few charges. When your battery gets to 48 volts it's important to use a lower PAS level as Low Voltage Cutoff (LVC) can occur if hard throttle is used or you are riding in a high PAS level.
