Shark retrofit bullet connector assembly guide
    Note: while this may be modified for use with other hardcase styles it was designed as a drop-in replacement for the connector module on 4-pin shark packs.
    Usage on other packs (including the revised shark pack with 5 pins) would be difficult.
    While shark contacts can be maintained almost indefinitely if following the recommended guidelines (check and adjust them occasionally, reinforce pack to frame) there are circumstances where they may need replaced. If you have this version of shark you can replace them with this connector, which fits into place. The original wires are then soldered to the cups on each bullet.
    Below is an exploded view of how the connector fits together and a pic of how it comes in the bag
    Click image for larger version  Name:	P1010073.JPG Views:	1 Size:	1.25 MB ID:	73249Click image for larger version  Name:	P1010065.JPG Views:	1 Size:	1.23 MB ID:	73248
    A view of what the bullets look like assembled
    Click image for larger version  Name:	P1010062.JPG Views:	1 Size:	1.11 MB ID:	73246
    The female side goes together as seen below. The two female bullets slide into the notched portion, then the matching notched portion is slid over top.
    Click image for larger version  Name:	P1010079.JPG Views:	1 Size:	819.2 KB ID:	73247Click image for larger version  Name:	P1010078.JPG Views:	1 Size:	838.8 KB ID:	73254Click image for larger version  Name:	P1010080.JPG Views:	1 Size:	767.8 KB ID:	73252Click image for larger version  Name:	P1010081.JPG Views:	1 Size:	757.4 KB ID:	73253
    The male bullets slide into the other piece
    Click image for larger version  Name:	P1010075.JPG Views:	1 Size:	703.9 KB ID:	73250Click image for larger version  Name:	P1010076.JPG Views:	1 Size:	793.4 KB ID:	73255
    Then the backplate is added to this piece and the included screw is screwed in. Take care not to overtighten the screw.
    Click image for larger version  Name:	P1010077.JPG Views:	1 Size:	652.2 KB ID:	73251
    That is it, now just slide the modules in place and solder the wires. There are 3 pairs of smaller gold connectors included but these are not needed with any Luna shark packs, they are intended for optional communication wiring between battery and controller. On the offchance you are modding a factory built ebike that uses this connection they are included but otherwise they can be discarded.
    Hi Paxtana - is this available via Luna? I struck out doing a search.
    My e-bike build details are now over there.​
      The shop wanted me to make some assembly document before listing it. If you to pm me we can handle it as a special order, otherwise should be available within the week.
        Great - thanks. I can wait. One of my shark packs made the "snap, crackle, pop - help me" sound during my last ride. I cleaned up the contacts and doubled up the velcro straps. But I've heard this warning before, and I don't like it, so ...
          Here is the link
            In order to install this u have to remove the case of the original shark battery with 4 pin? Then once the battery case has the 4 pin you can connect directly to the motor without the 4 pin base ?
              You would have to open it, remove the original module, and replace it with this one. It will only work if you have that kind of case and would only be recommended for skilled modders. The other side goes into the cradle. Both sides have to be replaced and soldered.
