Luna dropper seatpost adjustment
    Click image for larger version  Name:	170117_15693334085574.jpg Views:	0 Size:	90.8 KB ID:	102184
    You seat post is compressed and does not go up?
    First this is to loosen up the remote handlebar switch and slide it towards the stem (center of the bar) to ge some slack on the line.
    Then lose up the seat post camp to slide the assembly out of the bike and inspect the steel cable, it should be in the track and attached to the seat post lever.
    You can watch Brads' video it covers the removal of the dropper post and the adjustment.
    Your seat post comes up too slow?
    Then you should try to tighten the cable a little more, no need to remove the post there is a barrel adjuster under the remote lever, just turn it to tighten the cable a little. if not them you will have to remove the seat post and inspect the cable:
    Click image for larger version  Name:	Dropper adjuster.jpeg Views:	0 Size:	67.2 KB ID:	102185
    Dropper seat post complete manual
    If the above fixes did not work, and you for example have dropper falling when you sit on it, or slowly rising and not staying in one place, give this a shot.
    That little hump on the silver piece pushes the pin to activate dropper . it needs to be sanded down a bit so it is not putting pressure on pin.
ID:	103796Click image for larger version
ID:	103797Click image for larger version
ID:	103798Click image for larger version
    could not find the seatpost diameter anywhere...? going to order a longer post prior to receiving the med size X1 for my 33" inseam.
      It is 30.9. I recently changed mine to the Reverb axs wireless 125mm post. Works great.
        Hummm... that is interesting - my XL has a 31.6mm diameter seat post. Guess the post size is different between different X1 frame sizes.
          I am using a medium frame size. I also thought it was 31.6 initially but I can confirm that size would not fit a medium frame.
            i just got my medium frame couple weeks ago. my seat post diameter is 31.6. at first i thought they sent me the wrong size frame. but it is a 17.5 frame with 31.6OD post.
