Modding Luna Galaxy bike for fitting Direwolf
Name:	galaxy with dire.jpeg
    Much thanks to Ryan for these pics. This mod will work with size Large, our Galaxy bike, both the prebuilt electric version here and the pedal only bike.
    Direwolf is a fairly large battery style, as such it needs slight modification to fit.
    There is a metal rail on the bottom of the pack, this can be removed, then sanded down just a bit to fit (probably best not to overdo it). At this point it should be able to firmly wedge into the triangle.
Name:	bottom removed dire.jpeg
ID:	122064 Click image for larger version
Name:	sanded dire.jpeg
    Thank you. That is exactly what I wanted to know.
      I want to know, 033OPJZ0GZ
      192.168.1.1 IP address is provided by Linksys broadband router and some other manufacturing companies use the same ip address. Using the ip address, you can easily connect wireless network devices together with routers.
      The default IP address 192.168.0.1 is also written as 192.168.01 but the last one IP address is written false.
        Now that I have two parked side by side, I can confirm that the Galaxy Large and Medium frames have the exact same triangle opening.
        If something fits in the large frame, it will fit in the medium.
        The only difference that I find is that the medium 17" frame has about 2" less seat tube protruding above the top bar than the 19" large frame...allowing for a minimum seat height that is 2" lower, all other geometry seems to be the same.
        I love my 19" Galaxy, and once we get the medium all set up, maybe I can get it back from my wife...
          So do you just completely skip the magnetic mount with this setup?
            That is correct. It should be wedged in there pretty tightly so really all you would need is a couple straps.
