This topic is closed.
    Desmodromic
    It's actually Luna Cycle Owners and it has 700 members
    Most of the chat was about the X1 when I was a member
    Here's the group
    Owners Group for those who own a Luna Cycle product. For Sur Ron bikes we suggest the Sur Ron Owners group USA Please respond to both membership questions if you would like to join this group. Thanks!
      Does anyone know the torque values for the three big bolts holding the motor in? Don't want to crunch the frame just to change the brakes.
      Also, anyone has any tips for getting to this third 13mm nut?
      Click image for larger version  Name:	image_22355.png Views:	3 Size:	1.23 MB ID:	114094
      None of my sockets can fit in that spot, and there is no room for a regular wrench. Thin-wall socket maybe?
        I just tighten the bolts until they are tight enough
        I have removed my motor twice and so far no problems coming loose
        The nuts are locking nuts if I remember correctly
        Use a open end wrench if you do not have a socket that will fit
        • eskachig
          eskachig commented
          The bolts are super freaking tight - and I can't get to that nut with either a socket or a wrench, the rest of the motor is in the way. The local hardware store doesn't have a thin wall socket either, bummer.
          Maybe I'll call some auto stores, they sometimes have useful tools for tight spaces.
        • eskachig
          eskachig commented
          In a less than advised desperation move, I used vice grips. With them on, the nut can't rotate, and if you ratchet up the pressure the nut doesn't even get all that damaged. I can't say this is a good method, but it's something in a pinch. I'm ordering a thin wall socket for next time.
        Trim slightly with a Dremel.
          My new x-1 just got a flat rear tire. I can't for the life of me figure out how to break the bead. It almost seems like they are glued on. I have changed plenty of mtb tires and dirt bike tires and this thing has me stumped! They are maxxis minion dhr if that makes a difference. Hot tips anyone or a link to a video?
          • eskachig
            eskachig commented
            They are super hard to get off. What worked for me is airing them down completely, and then leaning on the bead with my weight, working around. I did that for a little, and the tire started scooting away from the wall towards the center channel.
          bhaaf
          I would like to know if it works
          Someone needs to order one and let us know.
          I love the 860C I got from Luna
          I did not like the stock X1 meter
          I'm assuming you order the one with the male connector right?
            There was only one 860C meter from Luna when I ordered mine
            Are there multiple 860C maters at Luna for the X1?
              On AliExpress there is one with a male and one with a female connector.
                I have not seen any confirmed postings about the Ali meters and if they work ok on the X1
                  If I knew how much of a pain in the ass it was to run lines on this bike I might have lived with the stock brakes bwahaha. But I'm finally in the club.
                  Click image for larger version  Name:	IMG_0038.jpg Views:	0 Size:	1.79 MB ID:	114288
                  Day 1 upgrades - Ali express carbon wheels with DT350 hubs, Bomber shock, short Luna cranks, SLX brakes, gripshift, Zitto dropper post lever, an old seat I had lying around.
                  After a little shakedown, still need to get the drivetrain sorted and nail down some creaks, but very promising. The stock PAS settings are a bit funky like everyone says. Level 2 creates a "chase the bike" feeling because the assist disappears whenever you're not on it, and level 3 is oodles of power wheelieing up the hill sort of boost. I'm going to play around with the 9-level assist, I think. But so far, super fun.
                  The real workout is at the end!
                  • tristanbrotherton
                    tristanbrotherton commented
                    Could you post a link or details on the wheels you bought?
                  • eskachig
                    eskachig commented
                    DB60: sorrry, it's been a while I didn't see this - I'd start at 600lbs if I were you.
                    tristanbrotherton : my wheels - https://www.aliexpress.com/item/32959936504.html
                  • jjdicecco
                    jjdicecco commented
                    Hello eskachig ...Did you have to buy any new hardware for the shock?
                  I switched my brakes to Shimano
                  It was not difficult to do
                  Removing the motor makes it so you can route the cables and brake lines way easier
                  • eskachig
                    eskachig commented
                    I don't think it's even possible without removing the motor. I had to take apart the battery box at the front too, to get the line through the head tube exit hole, and things are super fragile in there. Someone gorilla-armed all those tiny screws in the factory and the plastic was cracked and stressed before I ever got to it.
                    Anyway, most of this was just me being a noob. Last time I installed a new set of brakes internally routed brakes didn't exist, and I just zip-tied them onto my Turner without ever breaking a line. So this was a whole lot of new stuff done for the first time.
                  My Ali Express purchase works perfectly: https://www.aliexpress.com/item/4001...40694c4dz5lc1Q
                  • Desmodromic
                    Desmodromic commented
                    Which connector is the correct one for the X-1?
                  Cool, thanks for the update
                  I added to my Bikes Favorites list at Ali
                    Just found the best deal on the SNAIL 104 BCD chain rings.
                    My 40 tooth black was $9.99 and free shipping from the US
                    That's cheaper than on Ali and faster shipping
                    https://www.ebay.com/itm/MTB-Bike-Ch...T/254632812933
ID:	114316 Click image for larger version
ID:	114317 Click image for larger version
ID:	114318 Click image for larger version
ID:	114319 Received my x1 just about 2 weeks ago ... I absolutely love it... still modding it a little to put my touch on it but thought I would share a couple photos.
                      • jjdicecco
                        jjdicecco commented
                        The stem was easy to replace just be careful not to over tighten the compression plug in the steerer tube...I broke mine and had to buy a new from a local bike shop
                      • tristanbrotherton
                        Where would I buy that rear mudguard? Love it!
                      • jjdicecco
                        jjdicecco commented
                        tristanbrotherton I posted it right above.
