This topic is closed.
    If anyone is not aware yet, There are X1's that have a PAS problem in Level 1 and 2 of 5. Some work, some don't. There may have been a discovery of the software code responsible. If you have a BABE or X1, please read your controller software version and report back. Advise whether your PAS works in 1 and 2, and if your software ends in ".5" or ".6"
    To read go to "information", select "Controller info", then push the + button.
    If you would....just comment here below. Thanks.
    • bengreens
      bengreens commented
      My X-1 that arrived November 2019 has software 014.4 PAS1 and 2 are great (except for the delays in engaging and disengaging, which occurs in all levels)
      My 2nd X-1, which arrived September 2020, has software 014.5, and PAS1 and 2 SUCK, engaging intermittently and forcing me to pedal way harder.
      On the plus side, the new bike (I got a Large frame this time) came with a 38T chainring and no lockout of the highest gear (though I need to buckle down and do a thorough adjustment of the indexing and such, as the chain has jumped off into the stays twice).
      Also, no problems with the seatpost dropper or tight battery fit on the new bike, and all the bolts throughout are tight (the first bike had all kinds of loose fasteners and made lots of creaks/pops, plus one of the bolts holding the rear brake assembly on was cross-threaded and couldn't be gotten anywhere near tight enough to hold things in place).
    • bengreens
      bengreens commented
      This thread seems to have died on the vine . . . I keep hoping for news, and for more people weighing in. Is the issue maybe being discussed/addressed more fully elsewhere? I'm pretty bummed about my new X-1, and have begun to contemplate swapping controllers (motors?) with my old one.
    • kengps
      kengps commented
      There is more activity under the thread: "Software Survey"
    Just unboxed and went for a 5 mile ride yesterday. PAS 1 and 2 didn't seem that bad per the reports. Will see what version i have. Question: do we turn the battery off after ride or just leave it and charge as needed? Thanks
      I always turn my battery off, because it cuts power to the discharge port. This will help save your connector from arc damage over time. If you are leaving the battery in the bike, you don’t have to turn the power off, but it’s a good habit to get into.
      When you install or remove your battery, any current draw will cause small arcing at the connector. These tiny arcs will form pits on the connectors. By turning the battery off, you cut off any current, eliminating any chance of arcing.
      • Talltex
        Talltex commented
        How does the bms work on this battery I assume its not a smart charger so guessing its located in the pack if so cell balancing will only be done with the battery on. I may be way off anyone know how the luna bms operates
      I always hit the button on the battery to turn it off when I am done riding and it is charging
      I don't think the BMS circuitry has anything to do with the battery being on or off
        I have tried the walk function below assist level 0 and it doesn't seem to do anything. Is there some way it is triggered to work? I picked the rear wheel up off the ground and there is no wheel movement even with throttle engagement. What am I needing to do to get the walk function to start working?
        You have to walk at 1/2 mph which is why I never use it
        I have tried using it to get up and over big obstacles and forest log steps, but it is too slow to be useful
        It needs to be more like 1.5 to 2 mph to be useful for the situations I have tried using it
        • eskachig
          eskachig commented
          The walk function has been fantastic on my building's stairs, an absolute lifesaver. I put the seat into my armpit to give the tire some traction, and it climbs up by itself in a few seconds. The stairs are pretty steep and the bike is relatively long, so actually hauling it up ends up being a huge pain in the ass.
          I'm so glad it's there and that paxtana mentioned it.
        Does anyone know if the X1 will have replacement batteries available?
        Luna Cycle sales said they don’t have any replacement batteries available for the X1’s. That would be a problem if your battery fails. You’re stuck with a bike that you can't buy another battery for??
        Anyone know about replacement X1 batteries?
          SDebike
          "Repeatedly press Down until the walking mode icon is displayed. Then press and hold Down for 2 seconds and the motor will move the bike along at a walking pace. To stop, release the Down button."
          More like a baby crawl pace. I walk at about 2-3 miles an hour
          The Walk function on my X1 is maybe 1/2 mph at best
            My X1 was delivered two days ago. The battery is defective and will not charge. It arrived with a 70% charge in the battery. I was able to go on one ride and love the bike.
            But now have a battery that will not charge. It appears the BMS is defective with a permanent fault.
            So far Luna is very slow and helping resolve the problem with the battery. Has anyone else had issue with their battery or any service related issues and Luna Cycles response time to help resolve it?
              Sorry to hear that, stuff like that needs escalated to a technician so it can take a bit longer. Would be terrible if we spent weeks exchanging a battery only to find out it was something easily fixed like the charger or the port!
            Make sure you do not accept any answers from Tony at Luna.
            Make him go get someone that knows what they are talking about.
            Just my .02 from communications with Tony over the last 11 months
            • SDebike
              SDebike commented
              Thanks, I have been dealing with the head Tech Seb, at first was responsive to my email, but now that we have determined the battery is defective, not responding to my emails.
              4 days now with a brand new bike I can’t use
              I think they’re out of X1 batteries, so they don’t can’t help me. What should I do?
            • eskachig
              eskachig commented
              You can see if this dude still has his battery for sale, that way once Luna fixes yours, you'll have two - and have something to ride in the meantime.
              Otherwise seems like following up through the warranty process is just what you do, and you're already doing it.
            ask for this problem to be escalated to gary....we do have x1 bikes in stock atm so we can take a battery off of a brand new bike if it is defective...ask to speak with Gary...sorry this happened.
              Does anyone know the size of the stock stem? Is it a 40mm or a 50mm?
              • Desmodromic
                Desmodromic commented
                The stem on my small frame is a 45mm
              • eskachig
                eskachig commented
                That is a super funky size hahaha.
              Can someone let me into the fast electric bike group on facebook please. I also have a X-1 Ludi and PAS 1 and 2 out of 5 are super jerky and not usable, while 3 is a bit more than I would prefer. I'm hoping to find answers on the facebook group. Thank you.
              There's nothing on Facebook that's worth joining.
              This is the best place for Ebike info and help
                bhaaf
                Exactly!!!!!
                I am not sure why people continue to order Ludi on the X1's?
