Luna Z1 temp manual
This topic is closed.
    Luna Z1 temp manual
    Work in progress
    Click image for larger version  Name:	luna_z1_06__24220.1637641622.jpg Views:	0 Size:	757.8 KB ID:	144935
    we will fill up this manual up soon. the bike is really similar to the x2, the main difference is the motor and suspension linkage
    CHARGING THE BATTERY IN THE BIKE:
    For the Z1 users, you can also use the manual for the X2 for everything but the motor.. for that you can refer to the apollo thread:
    X2 manual
    Apollo manual
    Thank you for your understanding and ride on!
    If you have a questions that cannot be answered with these links please email support@lunacycle.com
    How to remove the bottom cover off the battery
    Click image for larger version  Name:	IMG_5064.jpg Views:	0 Size:	663.5 KB ID:	145220 Click image for larger version  Name:	IMG_5065.jpg Views:	0 Size:	659.8 KB ID:	145221
    BCD on the bike chainring: 130
    Troubleshooting
    Power turned off mid ride, what do?
    The main power switch on the bike may be going bad. test XT30 plug and see if it doesn’t work. if no joy try to jumper it to bypass switch
