Hello everyone,
Hope all is well! Just wanted to throw out there incase anyone was interested in upgrading or modifying their Luna Eclipse, that I just completed upgrading mine, and all went well. Here is what I did.
installed a 52V 2000W rear hub motor which included a 40 amp controller w/SW900 display. I also installed a 52V 20 AH down tube battery with 21700 Panasonic cells, which I installed 3 rivet nut screws that allowed me to mount the battery bracket, and its solid. The 40 amp controller slides right into where the stock battery went with all the cable slack. All cables routed the same as stock w/the same amount of zip ties where needed. The frame folds back together perfect with no issues. Everything was plug and play for the most part, with the transitioning from the belt setup to a single speed chain system being the most work, as far as researching . This set up is definitely MUCH faster than stock, which I have yet to max it out, I let off at about 39/40 mph since I got nervous haha, but it was still pulling me. I installed a torque arm as well since this setup for sure requires one, and slapped on some knobby tires w/slime. Here are a few pictures.
