Hey guys, i was trying to re-grease the m600 but stripped the connectors. Can you let me know know what these connectors are and where i can find them ?
Hi - this might be a silly question, but how long should the battery be charged before first use on the luna x1 enduro?
The charger will stop the charge cycle when it's done but basically it's 2-3A right, at 48v nominal ~54 output, watts are volts times amps, so lets say it is 3A that would be 54 x 3 = around 150w, meaning you could fill 150 watt hours in an hour. It is a 650 watt hour battery so if it was dead might take 4 hours. These are estimates of course, and the battery is shipped at 30-50% so maybe half that time
Originally posted by DB60 View PostAnyone know the size/specs of the headset for the X1? I want to order one before tearing it down to see what size it is. Thanks...
1 1/8" - 1 1/2"
I keep extra bearings on hand because I have 4 bikes with all the same sized headsets
The bottom bearing tends to take a beating and gets water damaged after a while
Originally posted by Jlyman View PostHi - this might be a silly question, but how long should the battery be charged before first use on the luna x1 enduro?
Arrived yesterday, I’m very happy with it.
Can I increase the seat height?
I know how to use the dropper and mine came working perfect. I’m 6’4 and ordered the Large size so the seat needs just a few more inches. Thanks for the help!1 Photo
- Likes 1
https://electricbike.com/forum/forum/knowledge-base/bikes-aa/102182-luna-dropper-seatpost-adjustment(filedata/fetch?id=102184&d=1582571107) You seat post is compressed and does not go up? First this is to loosen up the remote handlebar switch and slide it towards the stem (center of the bar) to ge some slack on the line. Then lose up the seat post camp to slide the assembly out of the bike and inspect the steel cable,
Hello
Perhaps this is not the right forum and for this I apologize.
I live in Spain and I have a Bafang M600 kit.
It has worked perfectly for 800 km and from there it started to fail intermittently.
With the battery charged, the battery appears at 0%.
At this time, the fault is permanent .... I turn on the system, the display shows the battery at 0% and error code 30 within 5 seconds.
I have checked the cables and they are fine. I have opened the controller and reconnected correctly and the problem continues.
I have contacted the provider and he says that it will be from the display or the controller.
Can you help me because of your experience?
or on the other hand direct me to another more specific forum where they can give me a solution?
thanks for everything
Go here for Bafang mid drives
https://electricbike.com/forum/forum...ang-mid-drives
It's a standard sized tapered headset
1 1/8" - 1 1/2"
