Advice on adjusting the derailleur: Posting this here - as I didn’t get any luck as a separate post:
I upgraded my X1 to use a 40T chain ring - and changed the chain to an SRAM 126 - 2 link ( removed two for fit) - after reading articles by other members. (I wanted a bit more speed on urban streets).
I am trying to adjust the derailleur to be able to use all the gears in the cassette. My issue is that to remedy the skipping on the lowest gear, I need to adjust the B screw to increase wrap around the gear. However if I do that to fix the skipping, there is not enough clearance in the second highest gear for the derailleur to clear the cassette and it binds.
As this is my first "nice" bike, I am not an expert, I just wondered if there is any other variable I can be trying to tweak to meet both of these objectives. Any tips?
Thank you!
Thank you!
