    Originally posted by steelersmb View Post
    How did you get the speed limit removed? If you go into advanced settings it won't allow me to adjust the max speed setting.
    You can't change the speed limit
      I ordered and received my new 860C from AliExpress. It works but in the advanced menu, I can't edit the max speed. Can someone confirm that if you ordered it from Luna that you can edit the max speed and does it make a difference?
        Look right above your post
          Just got my girlfriend’s bike today, put it together and took it for a ride. It felt very under powered in all assist modes, I could only hit 15mph pedaling moderately hard in a high gear. Then the motor cut out and the display read Error 10. Gonna call Luna tomorrow but any ideas of what I should check now? It’s a Ludi with the quiet gear.
            You might double check that both wheels spin freely. My rear brake caliper was slightly misaligned on delivery and put some extra drag on the rear wheel. Definitely made the bike feel sluggish on the 'first ride', though I didn't go far enough to trip the 'overheat'. Once I noticed the caliper and re-adjusted to free the wheel, it made a notable difference. You also remembered the spacers on the front wheel, correct? If you're missing those, I think the front caliper could also rub.
              It shouldn’t be under power. I’ve just used my PAS 5 on the techy trail. After that it’s too much power. Try to check the connection of your controller maybe something is loose. I had an issue like that and I found out that my connection is loose.
                I don't have Ludi and I never go above PAS 3, so something is wrong somewhere on your X1
                As was mentioned above, check all connections
                Take the plastic side panel off so you can see the motor connectors
                I show the motor connectors in this video
                  Hey all, I know the answer to this is somewhere in this thread but looking for a short cut. Took a big jump yesterday and went down pretty hard as the guy I was riding with went down right on the other side of the landing point. Bent my front brake disk and snapped off the thumb throttle. 2 questions, can I bend back a disk brake (even though I'm ready to upgrade to something bigger) and are there other throttle options available that work with this bike like a twist option? Thanks!
                  • eskachig
                    eskachig commented
                    Yes, you can true a brake rotor. Eg,
                    How to straighten a bent rotor on a disk brake system. This works for hydraulic and cable.-~-~~-~~~-~~-~-Please watch: "Let's bench test the rear derailleur ...
                    Can't help you on the throttle, but the stock one certainly looks flimsy. I'm thinking about taking it off.
                  • mw195
                    mw195 commented
                    I planned on taking my front up to 220mm, but got a 203mm instead (by accident). Figured might as well install it, but the new rotor has a very slight warp to it...not enough to bend out, but I cannot get rid of the scrapping. May go back to the stock 200mm SRAM rotor. Oh, the replacement was a Hope 2 pc floating disc that looks very nice but I just cannot get it to not rub. I intended to get the 220 rotor, and thought that was what i ordered, but the packing slip says 203 (I am guessing that when I selected Red carrier, since no Red220 are in stock, it defaulted to the 203mm. Figure, why not just mount it and when the 220 Red is available I can install that and move the 203 to the rear...But now i am thinking that it needs to go back.
                  Anyone looking to put their bike on the diet, the stock 800mm handlebar is a good place to start. It's 330g, pretty damn hefty. I replaced it with a 760mm carbon bar and it's literally half the weight. You'll need new grips too, I think the stock ones require the cutouts on the end of the bar and I've never seen a carbon one come like that.
                    Go here
                    I just received my Luna X1 ebike on Holloween :) It's an amazing bike and the price point is awesome My Luna X1 weighs 55 pounds. Not too bad at all for an Ebike. My carbon fat bike with a BBSHD weighs 58.5 pounds The first time I pulled the X1 front wheel out of the shipping box, I was taken back by how heavy the wheel was.
                    The wheel set alone dropped 5 pounds off my X1
                    • jjdicecco
                      jjdicecco commented
                      I went to that forum and when I click on the link for the wheel set it’s a blank page... would you be able to send me in the right direction for the carbon wheel set
                    • eskachig
                      eskachig commented
                      Here is the one I ended up with - you can also find the same rims with Novatec hubs which will be a little cheaper.
                      There are a few sellers that seem to source their wheels from the same factory. They have a few rim width and hole number choices that will fit our 2.8s - choose to taste. These wheels have 32 spokes, but I forgot to get them beefed up and they shipped with aero flat spokes - holding up great so far, though. After deciding on the rim profile you need to make sure it's a 27.5 boost set.
                    • jjdicecco
                      jjdicecco commented
                      Great thank you for the help
                    Took another look today. All the connectors are plugged in tightly. I took it for another ride and tried throttle only. The motor is spinning but not propelling the bike. I took it back home, raised the rear wheel, pegged the throttle. Just like I thought, motor runs but doesn’t move the wheel. Gotta call Luna now.
                    The tech who called to help yesterday wasn’t actually a tech He talked me through how to erase the code (it didn’t clear, btw) then said he didn’t know what to do and told me to send another email to support (they haven’t responded yet.)
                      If Tony from Luna responds to you, tell him to go get someone that knows what they are talking about.
                      His replies are often completely wrong
                      Gary is great and so are the bike techs at Luna that I have dealt with.
                        Ok, I’ll keep that in mind. Seems like I’m waiting in a support queue now.
                        I’m starting to think the quiet gear swap didn’t go well and that’s my issue. Here’s a video.
                        Watch "Luna X1 problem" on Streamable.
                          jjdicecco
                          "Hello I clicked on the wheelset link and it was a blank page"
                          I don't know why?
                          ​​​​​​​I just clicked on it and the page was fine.
                            Guys,
                            Anybody had issue with Error 30 on their bikes? It came out on mine and tried all the usual fix like checking all connections. I even went as far as removing the main harness from the bike and connecting everything outside. Still no luck. Since we have 2 E-09s at home, I decided to swap out the parts one by one to check which component was at fault. From the display to the buttons switch and finally to the motor. I swapped out my motor to the other (working) bike and the error came out. It also caused the system to turn on by just inserting the battery, without actually pressing the power button. Put the working motor back and system is fine. Safe to say it's the motor that's faulty.
                            Also wanted to know if anyone has had any experience dealing with warranty from Bafang directly since my bike came straight from Dengfu.
                            Thanks,
                            Walrus
