Here's some information about the fork. You can type in your serial number here to find out exactly what you have.
https://trailhead.rockshox.com/en/search/
I'm going to try some 29" wheels (they will fit the X-1's 27.5+ fork but I'll have to test to confirm on the back). They should offer less rolling resistance and a slightly higher height (might reduce pedal strikes).
https://forums.mtbr.com/26-27-5-29-p...l#post12585348
If your wheels have 100/142mm hubs, you can use these adapters to convert them to fit the Boost 110/148 spacing (standard spacing of MTBs sold today) of the X-1.
https://smile.amazon.com/Dymoece-Bic.../dp/B07LDR2XZK
If your wheels have 100/142mm hubs and use Centerlock discs, you can use these adapters but you will need 6-bolt discs.
https://www.ebay.com/itm/Boost-Hub-C...r=574033788210
And in case anyone wants to put Shimano 203mm discs in the front or back, here is the adapter you need to go from a 180mm post mount to a 203mm disc. You will need one for each brake caliper (stock mounts are setup for 180mm discs). The X-1 comes stock with 200mm front and 180mm rear discs. The front already has a 180 to 200mm adapter on the caliper.
https://smile.amazon.com/gp/product/B01BZBRCYY
If you want to use a 200mm disc in the back, use a 160 to 180mm adapter (it's the 20mm difference that you need because the back is already setup for a 180mm disc, so adding 20mm to 180mm brings you to 200mm).
Here's a QR axle (brand & generic).
https://smile.amazon.com/gp/product/B018LYENTU
https://www.ebay.com/itm/223583204892
