I have a VPower 48v 22A 1000W battery pack. Just recently the pack has started to cut-off on me while riding, and I have to reach behind and turn it off then back on again to get power. It tends to do this while on an incline or applying more than 1/4 to 1/2 of throttle. I used to be able to do 25+ mph now I'm lucky to get 17 without it cutting out. The pack is made up of 117 "18650S22 DHP-1605" batteries. There are 9 bats in parallel with 13 rows. I put my multi-meter to each series and they all register 3.7v+, it's usually around 50-51v area when the cutting out begins. When I plug in the charger, it charges for 5-10min. then goes green stating fully charged which it isn't. I have a new BMS on the way that I'm going to swap out(it was cheaper than buying a new charger), if that doesn't work I'll buy the charger. Any other suggestion I might want to try.
Schrockie71
P.S. Battery is 1yr. old with less than 500 charge cycles on it.
Just took a volt reading 51.2v and cutting out!!!
Schrockie71
