CMeilan light disassembly
    Disassembly may vary depending on model. First remove the plastic mount by pressing whatever release tab necessary.
    On the underside are rubberized coverings on the screw holes. Remove the covering.
ID:	56901Click image for larger version
    There is also a couple screws where the usb port is.
    Lift up the metal heatsink housing.
    After that, pull straight out on the clear light housing to show the 18650 cells within.
