Luna Lumenator How to Walkthrough
    This is the new Luna Lumenator light walk through of the features and comparison
    between the Luna light and Fisher Fab house light. Both are the same price at $199
    and are both top of the line lights however the Lumenator is a lot brighter check the video I made.
    As far as features the Lumenator comes packed full of those it comes with a display and can be directly plugged in to any BBSxx
    harness. The Fisher Fab light is smaller and does not come with a display and cannot be directly plugged into the harness
    you would need to run wires to the battery in order to use that.
    Out the box the Lumenator comes with 5 levels of assist mode or 5 levels of PAS but you can go into advanced settings with password 1801
    and that can be changed to 9 levels if you prefer that.
    It is very bright at 7000 Lumens I really believe it really does put out 7K lumens because it's considerably brighter than the Fisher Fab House which is 3200 Lumens
    at it's brightest setting.
    Here's a video where I go through the display settings. Sorry about the quality I'm not very good with cameras.
    https://youtu.be/9YDtYHXpwI4 This one here is a comparison between the Lumenator and Fisher Fab light https://youtu.be/7rXyKKctlRU
    Hope this helps.
    I received my Lumenator today and will be installing it tonight. I also have the Fisher Fab light so I'll be able to compare them easily. I am currently using an eggrider but can't see it with my pogies on...so the center display built into the light will be nice.
      Does the screen tilt too far down where you can't read it unless you hunch over or lean?
      • intramorph
        intramorph commented
        You'll be able to see the display. It does not tilt but it's a big display and can easily be seen from riding position.
      There is a slight tilt to the screen when the light is installed level or even slightly pointed down. I think you'll be able to see it just fine. ;)
        What screen did you have before? How does it compare to dcp 18?
        • intramorph
          It's pretty much the same quality as DPC-18 did you see the video?
        I had the DCP18 at first and then went with an eggrider. Have you looked at luna's website for the product description? They have some pictures there that would probably help you see the difference. https://lunacycle.com/luna-lumenator/
          Hope this helps.
          Are there modes like ECO/SPORT or ROAD/OFFROAD? If so, how do you switch between them?
          • intramorph
            There's no eco/sport mode but you can switch to 9 levels of assist modes. There's no need for eco mode.
          Any idea if it's limited to 52v. Or can it go higher.
          • intramorph
            It can be adjusted to work with higher voltage up to 72V if you look at the video it does go up to 72V but
            please make sure your BBSHD is or BBS02 controller is also capable of accepting a battery like that as well prior to
            just plugging in a 72V battery.
