BBSHD can not be fully inserted due to chainstay interference. How to resolve
    In the example below you got a fatbike with pressfit shell and 100mm motor.
    Grey lockring can fit, but black triangle bracket would just be contacting the pressfit adapter anyway so this is non-optimal even if the length were good enough to fit both lockrings with motor flush with triangle bracket. So while the assumption may be to use a longer motor, in this instance it would be pointless.
    Solution is to use a BSB stabilizer bar instead of the black triangle bracket.
    https://lunacycle.com/bsbf-1-stabili...s02-and-bbshd/
    https://lunacycle.com/bsb-1-stabiliz...s02-and-bbshd/
Name:	2020-02-17 17_20_24.jpg
