Can BBS02 and BBSHD be used with a 36v battery?
    No it cannot. 38v is the lowest it can be set. If you were using a 36 V nominal battery the controller would shut down the system when it is still about 75% full.
    The lowest practical configuration is 12S (a 44v nominal pack)
    edit: while this is still not possible with stock, you could try aftermarket firmware https://github.com/danielnilsson9/bbshd-fw
    Why not just reprogram the controller and change the low voltage cutoff setting?
      Changing lvc is reprogramming (technically just changing the configuration)
      38 is the lowest the lvc can be set in the config, the lowest the firmware will accept.
        ah okay thanks for the reply. Looks like i have a BBS02 to sell (Toronto Canada)
          Or sell the 36V battery and get a 48V one? I live in Toronto and already have a BBS02. Not sure I need another one right now, but who knows?
          • stts
            stts commented
            waste of time
          It is now possible for BSSHD to run with a lower battery voltage by using my open source bbshd-fw firmware implementation. It does not yet support BBS02 but I'm working on it.
          Open source firmware for Bafang BBSHD/BBS02 electric bike motor controllers. - GitHub - danielnilsson9/bbs-fw: Open source firmware for Bafang BBSHD/BBS02 electric bike motor controllers.
            Wow that is impressive
          • stts
            stts commented
            waste of time
          Could You help, i need to flash the original BBs02 48v 750w controller, i flashed the wrong code for bbshd, the motor has no respond , please help, need t bike to work
