Gear Sensor failing to detect shifts - gearsensor maintenance
    Maintenance procedure for sensor failing to detects shifts
    Gear sensor model: GSD5-12V 16.13-00019 but this will likely work with other models as well
    The most likely source of issues is going to be lack of friction between the gear sensor cable and the internal wheel that rotates when the cable moves, or too much friction where the wheel rotates on the spindle caused by mud or debris preventing movement of the wheel.
    Basics of maintenance
    Loosen the shift cable bolt on your derailleur so there is play in the cable.
    Unscrew the 2 silver screws that hold the cover on the shift sensor.
    The cover has a tiny spindle on it, with a wheel attached to it. Theres a groove in that wheel that the cable rides in, and when you shift up or down the wheel moves. Im guessing there is a magnet in that wheel and a hall sensor in the body of the gear sensor that tells it when to cut power. The wheel is on the only exposed component under the cover. If the wheel gets gummed up, or the spindle gets sticky the cable will slide in the wheel groove rather than spin the wheel, and thats the problem.
    All you need to do is pull the wheel off the spindle. Clean the groove on the edge of the wheel out with an old toothbrush, and put a tiny dab of grease into the hole of the wheel where it slides onto the spindle.
    Slide the wheel back on the spindle with the grease and spin it around a few times. It should move pretty freely now. Then just snap the cover and wheel back onto the gear sensor body, making sure the shift cable sits in the wheel groove. Screw the cover back on.
    Tighten up your derailleur cable holding bolt and you're good to go.
    Below is a summary on how a customer cleaned and degreased the cable after using too much grease on the cable, thus preventing the cable from rotating the wheel.
    I took apart the gear sensor and cleaned out dried silicone cement and grease. I cleaned grease off the cable and centered the hub on the gear sensor wheel. Everything is working fine now.
    I also added a section of bicycle tubing to cover and protect the gear sensor from water and mud.
    There was no sign of water and mud in the gear sensor.
    The grease I used (and completely cleaned out of the gearsensor) is fancy low-viscosity white grease I have for plastic-on-metal contact points on ski bindings. Seemed like it would be perfect gear cable grease, especially in Winter! Maybe too perfect for the gearsensor. The last thing was just making sure the hub on the wheel is
    centered. That makes inserting the cable easier.
    I'm the customer with the grease-related Gearsensor detection problems. After I cleaned out the sensor, missed detections crept up on me again. Once again I disassembled the sensor. I solvent-cleaned and lightly sanded the cable at the detector location. I solvent cleaned the pulley wheel. And I lightly greased the wheel hub (magnet). I got best-ever performance after that: 100% detections. Now I believe dried silicone had nothing to do with the problem. Missed detections were all about too-little friction between the pulley and wire.
    My problems began after I installed new Shimano SUS stainless steel cable, SP41 Housing, and greased the cable with Dow Corning Molykote EM-30L Synthetic Polyolefin (PAO) grease. I believe this cable/grease combination is just too slippery for the gear sensor. I greased the pulley shaft with Park Tool Polylube 1000.
    Click image for larger version  Name:	gearsensor 1.jpg Views:	1 Size:	26.3 KB ID:	26060
    Click image for larger version  Name:	gearsensor 2.jpg Views:	1 Size:	22.0 KB ID:	26061
      After this maintenance is done we would recommend protecting the gear sensor as shown in the link below
      Protecting your gear sensor from mud and debris
        Anyone familiar with newer model Shift Sensor model: LL-SS-01? It doesn't have two small screws holding it together. But under the sticker with model number, there is one tiny hole on one side and no scre visible. I'm having same issues of sensor not detecting shifts (90% of time). Was excited to follow your advice above until I saw this. I would pry it apart but first wanted to reach out to this awesome forum!
          Hmm.. can you take a pic? Maybe the new version just uses clips for easy assembly. If that's the case you might need a spudger.
        Paxtana , attached are couple of pics (front and back) of Gear Sensor. (What is a 'spudger'?)
          A spudger is a pry tool. Often they are sold as a set so you have a lot of options to pick the best one for a given scenario. It allows you to pry open something without marking it up.
          They look like this.
          It's a handy tool to have these days as a lot of stuff can be difficult to open. Smartphones, tablets, laptops..they all often require one to service the internals. I have the set pictured above, it cost $10.
          Looks like we might have recently switched to an alternate supplier so I do not have info yet on how to open it up, I'd probably start by checking if that hole has a screw in it and giving that a shot first. But if that doesn't work the spudger's probably the way to go. If it's not screwed in then it's either clipped in with tabs or just glued in. If you can get a pry tool between the two pieces and pry it apart you'd see the clips easily enough and can unclip it. If it's glued you would see that too and might need to pry it a bit harder, slowly working along the edges.
            Hey guys, think might be a little late to this thread.
            I had same problem with my gear sensor not picking up shifts at times..
            Had a gear sensor which were maybe have been glued together and i pried it apart using a screwdriver. I used a knife to cut around the glued (edges) part around the sides - first.
            I pulled out the circle bit of the spindle and cleaned it.
            I then used a little with WET CHAIN LUBE to grease the inside of the hole (where the spindle will go through) and cleaned of any excess (turns much more freely), also sandpapered the cable - only the part that touches the sensor!!
            Been working PERFECT.. ever since. I am so glad I came across this thread and this was my second sensor with the same issue)
            Make sure you don't get any grease/lube on the cable or the round thing (the bit that contacts the cable), it will just keep slipping past the senor.
            I did not glue the sensor back together just in case I MAY need to open it again, so i used electrical tape all over the sensor which don't bother me.
            Good luck Ebikers..!!!
            Oh yes, big thanks to the guys on this thread that help me fix this.
              For me the fix involved roughing up the extremely slick cable
                It's good to bump this thread once in a while, great tips!
                I did not roughen my cable, only the pulley, and mine slipped for a few days after lubing the cable with Aerokroil, to stop it sticking at 8F. I wish I'd thought to rough the cable, too, when I'd installed mine. Next time it's apart.....I bet that would be more oil-proof.
                  The cables these days are coated with something like teflon, they are really slick - I didn't think to roughen the wheel and the only lube was a tiny drop of tri-flow on the pin after thorough clean and degrease...
                • JPLabs
                  JPLabs commented
                  I understand the Teflon shouldn't need lube, and I ran my cable dry as long as I could, but water gets in, causing it to lock up in the cold. Lube helps to reduce that. Unless there's a good reason, a shift cable shouldn't be oiled. Figured I should mention that.
                  Makes sense! I don't deal with water... I'm a complete wuss when it comes to rain - frankly I just don't like it and old enough to not deal with things I don't like if I don't have to. Out here the winter rains aren't all that often and it's too cold. The monsoon storms in the summer are brutal and even the most sturdy sorts usually know better - I rode motos in som eof those and it's insane...
                Hi new here.
                I have had the same trouble with the gear sensor only working occasionally.
                the sensor is bonded together ( no screws ). I carefully opened it up with a sharp scalpel. The trouble with mine was that the plastic wheel that the cable should turn was not a tight fit to the central boss which is a magnet. So the wheel was moving but not the magnet.
                I cleaned both parts and put a spot of super glue on them and reassembled the sensor.
                All working great now.
                • JPLabs
                  JPLabs commented
                  Good tip on another way they can go wonky, thanks.
