COLOR DISPLAY ERROR CODES FOR BBS02 and BBSHD
    Here is a list of all the various errors for the two color displays Luna sells (the DPC-14 and the 750c)
    Please see error code table below, Hexadecimal will show H behind.
    Error Code Error description Error display with Hexadecimal Error display with Decimal
    0x01 Normal No error No error
    0x03 Brake signal No error No error
    0x04 Throttle on high position show 04H show 04
    0x05 Throttle error show 05H show 05
    0x06 Low voltage protection show 06H show 06
    0x07 High voltage protection show 07H show 07
    0x08 Motor’s hall sensor error show 08H show 08
    0x09 Phase line of motor error show 09H show 09
    0x10 Controller over temperature show 10H show 16
    0x11 Motor over temperature show 11H show 17
    0x12 Current sensor error show 12H show 18
    0x13 Battery’s temperature sensor error show 13H show 19
    0x14 Motor‘s temperature sensor error show 14H show 20
    0x15 controller‘s temperature sensor error show 15H show 21
    0x21 Speed sensor error show 21H show 33
    0x22 BMS communication error show 22H show 34
    0x23 Head light error show 23H show 35
    0x24 Head light sensor error show 24H show 36
    0x25 Torque sensor error-Torque show 25H show 37
    0x26 Torque sensor error-speed show 26H show 38
    0x30 Communication error show 30H show 30
