24V Battery how to lower LVC
    1) Just picked up a BBS02 and just getting things setup. I was told by Luna that a 24v battery would work. There is a 24v,36V,48, UBE setting in the settings of the display. I've tried setting it to 24v but the battery indicator still says 0% battery with red borders. I have a programming cable and 4 PC's later, I've found one that can connect. I cannot change the Low voltage cuttoff below 38. What AM I missing here?
    2) for PAS 0 if I just want to use throttle and no pedals I set the Current % to 1 and speed % to 1 and under throttle set designated assist to 9 correct?
    Thanks! excited to just get rolling...
