I have two BBS02 motors installed and in use for about two years. On one motor the pedal crank has started turning when the motor is throttle powered. It does not take too much leg resistance to stop this behavior.
The other BBS02 motor does not behave this way in that the pedals are not prone to turn when the bike is under throttle power.
If anyone has had this problem and successfully solved it please respond.
