Luna Black Box
    Luna Black Box
    Section 1
    How to program your BBSxx using the Luna Profiler
    1. Ensure the display is turned off, and the battery dicconnected.
    2. Disconnect the display from the wiring harness
    2. Now connect the black box to the wiring harness
    3. Turn on the battery, this will power up the black box.
    4. This screen will now come up.
    Click image for larger version  Name:	20180131_084106_edited.jpg Views:	1 Size:	74.3 KB ID:	57581
    5. If you want to change for example to the Luna BBSHD settings select ADV. Profiles
    6. Now select the BBSHD on the top right.
    Click image for larger version  Name:	20180131_084111_edited.jpg Views:	1 Size:	65.1 KB ID:	57583
    7. It will now ask to confirm this operation, select yes if you want to add the Luna Settings
    Click image for larger version  Name:	20180131_084116_edited.jpg Views:	1 Size:	73.0 KB ID:	57584
    8. The Luna hot rod settings will now be in the controller.
    If you wanted to check the current settings you can go into Advanced. These will be the current settings.
    An example below of what Advanced settings will look like
    Click image for larger version  Name:	20180125_110835_edited.jpg Views:	1 Size:	58.5 KB ID:	57585
    9. Toggle though from Basic, to pedal assist and onto throttle to look at all the new settings.
    Section 2
    Adjusting settings in Advanced mode. This section covers adjusting the maximum amps.
    The BBSHD can be programmed to 30 amps and the BBS02 can be programmed to 25 amps.
    Changes to the amps can be made in this advanced settings
    In this case we are going to adjust the maxium amps from 30 to 18 in the BBSHD, this will reduce the watts to aproximatley 750 watts.
    1. Follow steps 1 to 4 in section 1
    2.Open advanced settings
    3.Select 30 on the touch screen (under the red arrow)
Name:	20180125_110847_edited - Copy.jpg
    4. The following screen how come up
    Click image for larger version  Name:	20180208_171538.jpg Views:	1 Size:	289.2 KB ID:	57648
    5. Type in 18 amps and then select the back arrow
    Click image for larger version  Name:	20180208_171550.jpg Views:	1 Size:	330.0 KB ID:	57649
    18 amps will now be programmed into the controller.
