Bearing difference on BBSHD vs BBS02 rotor
    This thread is intended to highlight a design difference between HD and 02.
    On BBS02 the bearing that sits inside the core is pressed into the case, while on the BBSHD this is pressed onto the rotor itself.
    Click image for larger versionName:	02.pngViews:	1Size:	311.3 KBID:	69561Click image for larger versionName:	hd.pngViews:	1Size:	433.2 KBID:	69562
    For most people this is not a necessary piece of info. However it may be notable since there was a longstanding tip for folks getting core vibration on 02 to add loctite as shown in the pic below between the shaft of the rotor and the bearing. The usefulness of this tip is debatable but in any case this should not be attempted with BBSHD, it was only applicable to BBS02 as the design change makes this a non-issue.
    Click image for larger version  Name:	^FF717EA4FCCFE322B56BE013D391C42D38AC7975A9C1F9F8D0^pimgpsh_fullsize_distr.jpg Views:	1 Size:	378.5 KB ID:	69563
