What is the difference between the BBSHD and the BBS02?
I believe the BBSHD is better and is worth the extra money for MOST users for these reasons:
One of the biggest considerations that people forget, the BBS02 requires a lot of shifting to keep it in the optimum gear level to keep it from getting too hot...the BBSHD you can shift in a middle gear and forget it for the most part except when doing extreme climbing.
In some cases, the BBS02 is a better choice. Here are the advantages of the BBS02
- The BBSHD was completely redesigned, almost every part is different.
- The BBSHD uses much beefier components, and a beefier controller.
- The BBSHD is overbuilt to put up with the 30 amp amperage, the BBS02 is at its max at 25amps.
- The BBSHD is 10 percent more efficient which means more range AND more power
- The BBSHD is 3 pounds heavier than the bbs02
- The BBSHD i s considerably larger than the bbs02
- all the external connected accessories are the same (dispaly, throttle, ebrake, wiring harnass etc)
- Both mount in the same way to your bottom bracket
- The BBSHD is much more powerful not just by the amp numbers, but in real world performance.
- The bbshd is 10 percent more efficient than the bbs02
- It puts out way more torque than the BBSO2
- It is far more reliable than the BBS02
- It is very possible that Bafang will release higher amperage controllers in the future for the BBSHD
- The BBSHD is hot roddable, the bbs02 is not...so your future proof.
- The BBS02 is much more affordable than the bbshd
- The BBS02 is 3 pounds lighter
- The BBs02 is smaller in size
- The BBS02 has been around longer and is better known entity.
- There are many more upgrade chain ring options for the BBS02
- You cant afford the bbshd
- You want to stay legal and the 750w ttitle on the BBS02 does make it more legal for street riding
- you really don't need the extra power of the bbshd
