BBS02 Troubleshooting
    Q. My pedal assist is not working properly. Not starting at right time, giving max power when it should not etc.
    A. Controller issue, possibly fixed using the programming cable and this https://penoff.wordpress.com/2016/01...sion-software/
    Q. I need to replace my controller. Is there a guide?
    A. https://www.youtube.com/watch?v=19tj9egnUbY
    Further troubleshooting tips and tricks http://electricbike.com/forum/forum/...nit-not-moving
    Q. PAS and Throttle mode works sporadically. Throttle mostly doesn't work but once in a while turns on for one burst. PAS mode practically stopped working Red exclamation mark flashes momentarily on the display right of PAS level indicator. No error code recorded
    A. Check your ebrake sensor. If not configured correctly it may sporadically send motor cutoff signal until it is adjusted.
