How to determine controller version on BBS02
    There is a version A and version B which have slightly different shapes..are there any other ways to be sure which version you have?
    There is one quick way of knowing the version of your BBS02 without opening the drive. The version B looks something like this, notice the B on the BBS02
    The pinion gear, bearing, controller, nylon gear and the circular plate are different from the old BBS02.
    the controller
    The pinion gear
    The circular plate
    You can read more about the Version B BBS02 from karl
    https://electricbike-blog.com/2016/0...-tells-no-one/
    this picture.... the picture is in the controller add on luna cycle site.
    also if it was bought from luna it will have Luna Cycle etched on the motor side of the drive.... Click image for larger version
      I'm afraid that there are more differences than those mentioned above. I've learned it the hard way.
      The chainring gear is also different: it has to match the pinion gear.
      I have a BBS02B 36V 500W
      Serial number is 1604015447.
      Pinion gear model is 3 (a model 2 variation with an o-ring at the 12mm end). - http://www.ts-export.com/_mb/bbs02_3...6/IMGP0411.JPG
      Nylon gear model is X-2. - http://www.ts-export.com/_mb/bbs02_3...6/IMGP0391.JPG
      Chainring gear model is LD-2. - http://www.ts-export.com/_mb/bbs02_3...6/IMGP0397.JPG
      There is also a number engraved on the crank axle shaft: GXY2016-03-28-Z.
      Paul sent me a chainring gear model LD and it doesn't fit in.
      More info and photos there: https://endless-sphere.com/forums/vi...t=900#p1260795
      Thanks for the info. Will now buy all my spare parts from Luna from now on whenever available.
      Would purchase: a spare 36V controller, a nylon gear, a chainring gear, a pinion gear, a circular plate, a complete axle bearing set, a paper gasket for the motor side and 2 rubber seals. I already have an account.
