BBSHD Gearsensor controller showing leads
    Here's the controller with all leads. GS is yellow. The GS lead usually comes with a black cover cap.
Name:	Screen Shot 2016-06-14 at 11.39.50 AM.png
      that's great if you have a new BBSHD or have a new controller. (as my son has)
      But mine does not have the extra lead so i need a converter cable or i lose a break sensor
      A "Y" splitter would be great
      does anyone make one of these?????
      Yep looks like it broken
      cant find anyone selling a Y splitter for the brake sensor cable
      if you have seen one send a link please
      i could buy a cable and wire it into the controller i supose..
        I promise, the brake version is no better than a back pedal or tap on the brake lever. The controller version is much better. That's the opinion of a user who was a beta tester and has had them for more than two years. There is also a button. But a tap on the brake has worked for more than 2 1/2 years here. Same chain for several thousand miles too. Seriously this whole bit is seriously over played. If you're a commuter and path rider just back pedal or tap that lever and shift. If you're a BBSHD rider, who needs to shift under stress in normal riding? I've gotten so used to riding in third gear with speeds up to 24-26mph that I find I don't need to shift. Ride. But then I don't have multiple displays either. I watch the scenery not the displays. VBG
          http://bfy.tw/6Lzc
