BBSHD and BBS02 programming basics
    https://electricbike.com/forum/forum...shd-mid-drives
    Hi, first timer on this forum and I hope I have the right topic.
    I have a 750w and a 1000w Bafang mid drive motor. They are both hooked up and connected. One to a free ride bike, the other to an xc bike. Both fly like the wind. Neither of them have the brake motor cut out levers as they are hydraulic brakes and this was not possible to connect. The problem I have is that when riding at any speed with PAS, once off the throttle or off the pedal, the motor takes at least 1.5 seconds to stop powering the chainring. Is there any way of getting quicker response on motor cut out when coming off the throttle or pedals?
    If you pedal backwards that will cut motor off. There is no way to adjust the programming to completely eliminate the delay.
      Thanks Oledave, I'll try that!
        Thank you very much for the advice
