Proud owner of the amazing M600 Ludicrous V2 controller?
Here you will find all the info, software, documentation and support from the engineering team to get the best out of this extreme piece of tech.
<<<< DOWNLOAD THE LATEST USER MANUAL >>>>
The USER MANUAL contains updated links to software downloads. The development pace is pretty fast right now so the manual is a fresh export from our internal google docs documentation to keep users updated.
Latest software release: 2022-11-25
Firmware: v6.0
Android app: V6
Apple app V6
Support note about the X2 with the Ludicrous V2 controller:
DO NOT UPDATE YOUR FIRMWARE IF YOU OWN A X2/X2.5 SHIPPED AFTER DEC 2023. PLEASE CONTACT LUNACYCLE FIRST, NOT ALL FIRMWARES ARE UP TO DATE ON THE APP
If you need to replace the controller this is the video you need to watch, as you can ruin the controller.
CHANGELOG:
2022.11.25 (V6.0)
*M600 v2 is now officially supported in the VESC codebase and integrated into VESC Tool for iOS and Android. From now on it will receive updates from the app stores
*Fixed bugs and general improvements
2022.05.09:
* Power button hold time for shutdown reduced
* Don't shutdown if the power button is pressed for a long time
* Start CANbus thread sooner to avoid Error25 on startup
2022.05.05:
* Quicker battery % settling time on startup
* PAS ramp down shortened to 0.35s max
* Offset Correction button color follows light/dark theme
* PAS filtering can be tuned from the app
* Quicker response to button shutdown
* Show firmware name (YYYY.MM.DD)
2022.04.29:
* Wheel size support in DPC-240 display
* Fix DPC-240 speed limit value to a road-legal 20mph
* Add Field Weakening sliders
* Remove Upload All button
* Guide users through encoder correction steps
* Read settings on UI startup
* Use imperial according to system locale
* Fix gauge cluster settings dialog
* Wheel diameter based on standard rim sizes instead of rim+tire diameter
* Friendlier warnings during update process
* Fix version not showing in firmware tab
* Estimate range from battery level and average Wh/km
* Estimate battery level from resting voltage and Wh tracker
* Store encoder offset and odometer in ram4 to make it persistent across fw updates
* Add throttle, torque sensor and 12V rail data to the logs
* Protocol compatible with VESC Tool for iOS and android from app stores
* Custom UI loads 15% quicker
* 10 minute auto shutdown
* Battery % more filtered
* Shift sensor support on new hardwares
* M600 prevent shutdowns in PAS 0
* M600 odometer support
* Light and Dark themes supported
* Firmwares rebased to the newest official vesc release
* App remembers logging enable switch
* Disable pairing to prevent lockouts
* This is a 32bit app build, works on 32bit and 64bit devices
* Motor can produce torque while spinning in reverse
* Fixes shutdown when accessing the display settings menu
* Motor Temperature cutoff starts at 105°C and ends at 120°C
* Quicker throttle ramping
Plus over 250 contributions to the VESC codebase for under the hood improvements, see VESC changelog.
