Incomplete; to be updated later
Keep formatting throughout.
Needs specified if this is just a bolt, a screw, or a bolt plus nut
Needs specified diameter plus length not including the head, i.e. M3 x 10mm
- 860C - Selector Switch bolt type: m3 bolt
- 860C - Screw type for back of display:
- 500C - Bolt type: m4 x 8mm Allen head regular thread standard pitch. Bolts directly into a threaded metal housing.
- DPC 18 - Selector Switch Bolt type: M3x10. Nut not necessary. Screws into buttons selector switch.
- DPC - 18 Mount type for back of display: M3 x10 . Nut not necessary. Screws into the display mounts.
- DPC 14 - Selector Switch Bolt Type: m3 x 10mm. Screws into a m3 nut. Nut is necessary to screw in.
- DPC - 14 Mount type for back of display: m4, unknown length. Possibly m4 x 10mm. Screws into a nut. Nut is necessary to screw in.
- DPC240 - Mount type:m3x15 for the display part
- DPC240- remote m4 x10mm
- Crank bolt type for X1 bike and BABE: m15. like this. or this.
- Eggrider bolt type: Allen head m3 x 8mm machine bolt. Bolts directly into a threaded metal housing. Fine thread, standard pitch.
- DPC 07 - bolt type
- 750C - bolt type for back of display
- standard thumb throttle : m4 x 16mm machine bolt. Bolts directly into a threaded metal housing. Fine thread, standard pitch.
- Left thumb throttle
- Surron controller, terminal bolts for phase wires: socket head M6*16
- Eclipse bolts for mounting sprocket to face: Allen head M4 x 10mm
- Bolts for mounting chainring to bbshd motor itself: M5
- M600 crank bolt: ISIS M15
- Surron jackshaft bolts - m6 x 16mm, 1mm pitch
- Surron CR80 adapter bolts - m8x1.25 16mm long
- Wheel spacers - Apollos are same as matte X1 (proprietary, contact luna)
- Wheel spacers - Galaxy colored X1 use different spacers (proprietary, contact luna)
