Bought 2 of these tires from Chain Reaction Cycle and after a couple rides these are my initial thoughts on the purchasing process and the tires.
New tires needed already?
After finding some cords showing in the main center section of my OEM Huffy rear bike tire, it looked like it might be time for a replacement.
Yep, seeing daylight thru it put the replacement on high priority.
What to replace it with?
The original tires were 27.5X 1.75 (44-584) with fairly smooth all road treads. Rode well on the paved bike paths. But had a bit of tendency to bounce or slide to the side a bit if hitting a small obstruction on the road. I.E., small piece of gravel, or twig... Had an inflation recommendation of 40 psi, which was very solid and unforgiving ride wise.
So, I opted to upgrade both tires to slightly wider ones, as I have plenty of room. With a heftier and wider tire tread. These 2.0" wide tires should fit well on my 20mm inside diameter rims, with a very forgiving inflation recommendation of 35 to 70 psi.
After a bit of research on replacement tires, I ordered from Chain Reaction Cycles in England as per a recommendation in this thread...
https://electricbike.com/forum/forum...d-and-welcomed
It seemed the hardest part was finding what I wanted in the size I wanted, of course at a price that was acceptable.
Shipping from overseas may have been a bit risky during the height of Covid. But had absolutely no problem at all at this time. You do have to open an account on their website.
Shipping costs were $9.99, with a delivery date of 6 to 10 days.
Chain Reaction Cycles was right on the money with Order confirmation, shipping dispatch notice, to DHL's tracking service keeping me aware of my orders every movement.
Right down to delivery texts, and truck tracking right to my doorstep... just freaking awesome. And was delivered to me at their minimum quoted window time of 6 days.
Delivery in a grey plastic bag might be a little minimalistic, but hey what can you do to a bike tire?
Would have liked to perhaps have at least some paperwork included, but nothing else was in there. Just the tires informational cardboard wrapper around each tire. That had some installation instructions pictured on the back. But both the exact size and type ordered so no worries.
Installation and ride...
Tire installations went very well with no surprises or problem with fit. I like to use talcum powder to keep things from binding and sticking. And the beads went right into place.
Good looking and thicker tread at the slightly wider tire size was just what I was looking for, with the reflective white tire strip on the side a bonus. But how do they ride...?
Well, very pleased so far with the inflation set at 60 PSI. Takes the unevenness of a mowed forest path littered with small twigs and tree roots with ease, albeit with a firm ride. With performance on the paved roads and trails with surefooted, easy rolling quietness.
Will be testing at lower pressures to find a good compromise between stability and a softer ride if possible.
