hi guys does anyone knows any alternative way to remove this crank arm of bbshd? there's no more threads for my crank puller tool to screw in :(
Need help removing BBSHD Crank arm :(
Originally posted by New Mariner View PostThis recently happened to me. Tie rod puller kit. Look like oversized tuning forks. The smallest one 11/16 will work. Advance Auto has the kit to be borrowed. You can do it in the parking lot. Saved my bacon!Fabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
You should consider a Sturmey-Archer hybrid drive. Up to 27 speeds and your unused front derailleur shifter is probably compatible. The 42 tooth chain wheel in low will give almost the same ratios as the 30 tooth Mini. I was using this cassette in the calculations. 12,14,16,18,21,24,28,34
- Likes 1
Maybe a puller will work. http://www.ebay.com.au/itm/like/190911635024?chn=ps
The other option is to just cut it off
Originally posted by pcliteuser View Postfinally my threadless crank arm is now gone! :D what i did was I removed the cap and just ride for a week and it fell off naturally :DFabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
- Likes 1
You'll need different nuts for removing a bike crank without actual pullers, the large and small sizes. For the smaller ones (M8) I recommend using the Park Tool's CCP 22 to loosen this bolt size. Otherwise, you can use CCP 44 for larger sizes like M14 and M12.Last edited by Robert07; 03-29-2022, 08:12 PM.
