BIKE\FORK | Luna Lander Fat / Mosso / Sondor fork |
Luna Lander Thin | Rock Shox Bluto / Luna Lander Carbon |
LAUF CARBONARA / WREN INVERTED / RST RENEGADE |
DNM USD-8S / ROCK SHOX RC 200MM |
Mini Mosso Folder | |||||
Giant momentum | |||||
SMOOTHIE Cruisers | |||||
Luna CycloCross Ebikes | |||||
KHS 500 PRE-2018 | |||||
KHS 1000 PRE-2018 | |||||
KHS 3000 PRE-2018 | |||||
KHS 500 2018 | |||||
KHS 1000 -2018 | |||||
KHS 3000 2018 | |||||
LUNA APEX | |||||
LUNA APOLLO | |||||
LUNA LUDICROUS FS | |||||
SONDORS FAT | |||||
SONDORS THIN | |||||
Bolts-on, no modifications required |
Will require changing the front hub to a 135mm wide w 9mm QR | |||||
Will require a new head set converter and some 15mm to 9mm axle adapters (may also require to change the hub to 150mm 15mm thru axle) | |||||
Will require a new lower head set converter and crown race (see below) |
FORK MODEL | Headset / Steerer | Dropout Width | Axle type | Axle to crown lenght |
Tire Diameter | Tire Width |
Mosso /Sondor basic fork | 1 1/8" straight threadless | 135mm | 9mm QR | 520mm | 26 inch Fat | 4.8" depending on brand |
Luna Lander Fat | 1 1/8" straight threadless | 135mm | 9mm QR | 520mm | 26 inch Fat | 4.8" depending on brand |
Rock Shox Bluto | Tapered 1 1/8 to /1.5" | 150mm | 15mm thru-Axle | 531mm |
26 inch Fat | 4.8-5.0" depending on brand |
Luna Carbon Fat | Tapered 1 1/8 to /1.5" | 150mm | 15mm thru-Axle | 540mm | 26 inch Fat | 4.8" depending on brand |
Wren Inverted Fat | Tapered 1 1/8 to /1.5" | 150mm | 15mm thru-Axle | NA |
Lauf Carbonara Fat | Tapered 1 1/8 to /1.5" | 150mm | 15mm thru-Axle | NA | 26 inch Fat | 4.8" depending on brand |
RST Renegade Fat | Tapered 1 1/8 to /1.5" | 150mm | 15mm thru-Axle | NA | 26 inch Fat | 4.8" depending on brand |
Rock Shock RC 200 | 1 1/8" straight threadless | 110mm | 20mm thru-Axle | NA | 26 inch | Depends on diameter and brand 2.5" |
DNM USD-8S | 1 1/8" straight threadless | 110mm | 20mm thru-Axle | 540mm | 26 inch | Depends on diameter and brand 2.5-3" |
Luna Lander Thin | Tapered 1 1/8 to /1.5" | 100mm | 15mm thru-Axle | NA |
700C | Depends on diameter from 1-2.25" |
KHS 2018 500 : Not compatible with the Luna lander or the other forks. The steerer tube is a straight 1 1/8" but you can swap the lower 1 1/8"internal headset and crown race with a external tapered 1,5" converter to be able to mount a tapered fork like the RS Bluto, Wren, RST or Lauf on your KHS 500. To convert your KHS500 : The headset can be the NukeProof EX44-40-B5 and the Nukeproof CR-B-2015 onward 1.5" CRown race (Chainreaction cyles) Or the Cane Creek 110 EC44 Lower Conversion and Cane Creek 110 1.5" Alloy Crown Race (from Jenson USA.. but a lot more $$)
