How to trim SRAM DD3 spring retainer
    To be able to use this DD3 kit you will need to modify the spring retainer.
    Tools needed:
    Rotary tool (Dremel) with cutting disk
    Vise or a piece of wood and drill/drillbit
    Flathead screwdriver
    See below for an instructional document on how to do this.
    Backup link
    I really need this attached file but it seems to be missing. If someone has a link that works please post it for me.
    Thank you very much
      Should be accessible long as you are logged in, but I went ahead and added a second backup link to the post if needed.
        just let me say how much I appreciate this link. It's help is just what I needed.
        Thank you so much
        ancient
        Now if I could just talk you into building the wheel – snicker
          Which of your ebikes would this 135mm axle fit? I'm looking at Those ebikes under $3K.
            Hard to say for sure, that's not really something we keep track of for every model. Generally speaking if the specs are right then it should fit, though we don't usually make promises when it comes to fitment as frame specs can vary.
