While a lot of pedals have flats you tighten with an adjustable wrench these are a bit different.
If we look at them on the side there is a spot to insert an allen key. This is how to install the pedals.
A 6mm allen key fits. You may need to remove the cranks in order to install the pedals so your allen key can fit.
