http://lunacycle.com/connectors/xt90...teries-as-one/
Be careful with this one. Both batteries should have identical cells and charge level (mostly the same voltage). If voltage is very different the packs will equalize quickly, potentially damaging the pack.
When you are ready to charge, do not charge while the packs are still in parallel. Parallel charging could be dangerous because if one BMS fails it will continue to charge. Packs MUST be unplugged from eachother before charging.
For more info:
http://electricbike.com/forum/forum/...d-li-ion-packs
For more info:
