How to install Bafang Ebrake sensor for hydraulic / universal brake levers
    The sensor is the black rectangle on the end of the wire. When the magnet is a certain distance from the sensor the motor will operate. It cuts power to the motor when the magnet is moved farther away.
    So the goal is to position the magnet/sensor in a way that when you pull the lever, it pulls the magnet away from the sensor. And when releasing the lever, it is a close enough distance that the sensor detects the magnet. If you have just finished install and your throttle is not working, this should be one of the first things you check!
    So there are a lot of possibilities for placement depending on your situation.
    https://electricbike.com/forum/forum...-brake-sensors
    https://www.youtube.com/watch?v=dlvBxedXTZ8
