Silicone insulated wire with high strand counts usually cannot be found at the local hardware store. Why not use " regular " wire ?
Product Link: Silicone Insulated High Strand Count wire at Luna Cycles
*** Just a personal comment here, I shop for this stuff a lot and Luna is selling it at what must be their cost because these prices (06-2016) are VERY competitive with having to buy it in bulk. Thanks Luna !
- High strand count wire conducts better with less resistance (i.e higher performance).
- False
- The measurable difference between high strand 10 AWG wire and a 10 AWG solid core is minuscule at the lengths that bike builders use. By definition it is the total cross section of the copper that determines the rating.
- High strand count wire is more flexible and less prone to breakage.
- True
- The smaller individual strands are better suited to repeated flexing without breaking and the soft silicone insulation is more pliable than most wire covering materials. In an eBike environment where wires are plugged and unplugged stuffed in bags and cases ,and vibration can be an issue, this is a desirable material property.
- High strand count silicone insulated wire is also higher temperature rated.
- True
- Heat is the enemy in most eBike scenarios so why outfit them with high temperature wire? Because when you use a lot of heat to make a strong solder joint in larger current carrying runs, such as between 10 AWG wire and an XT-90 connector a lot of the soldering heat can creep up the wire, standard insulation can melt or shrink back exposing more of the conductor. This makes for a sloppy looking connection and can create a short hazard if that exposed conductor is not re-insulated with shrink tubing or other means.
- Are there other benefits to using this type of wire?
- Yes
- Silicone is an excellent insulator and has excellent moisture resistance properties. This is especially true at connectors where the ability for moisture to "wick" up under the jacket and cause unseen corrosion is almost non-existent in silicone insulated products.
