Modifications, adjustments, tips & tricks
Here is the list of the available modifications, tips & trick:
- Adjusting/setting the headset
- Bleeding the brakes
- Sur-Ron pedal system
- Changing/upgrading the headset
- Adjusting the chain tension and rear wheel alignment
- How to replace or adjust the primary belt tension on Sur-Ron
- Removing the jackshaft castle nut and replace it with a nyloc nut.
- Tire and Tube replacement
- RST Killah front axle replacement
- Upgrading /replacing the brakes
- Charger and battery connector
- Street legal mode
- Adjusting /removing e-brakes sensors
- Replacing the handle bar with riser handlebars
- Replacing the mechanical handlebar throttle
- Replacing the electronic/mechanic throttle with aftermarket E-Throttle
- Locking/replacing your grips
- Adjusting your front fork
- Making a key copy
- Setting up the rear shock
- Picking the right front fender
- How to replace the seat on a Sur-Ron
- Aftermarket cranks for the Sur-Ron pedal system
- How to modify the seat for moving it back
- How to remove the kickstand sensor
- Tuning the Rockshox Boxxer RC
- Adding a voltage meter to your Sur-Ron
- Removing the kickstand sensor
- Aftermarket Sprockets - chain length needed
- Primary chain drive conversion
- Placing the dust cap for DNM fork
- Equipment to change from belt drive back to chain
- Programming the Sur-Ron Controller
- Front fork upgrade
- Aftermarket parts upgrades
- How to remove the brake lever blade
- How to replace RST fork spring and make it firmer
- How to fix the battery latch or remove it
- How to install seat extenders
- How to replace the spring (to a firmer one) on a Fastace or DNM shock.
- How fix spongy brakes
- Changing the rear wheel bearings
