Brushless DC Motor Flipsky Battle Hardened 6384 190KV 4000W for Electric Bike
    https://twomotor-com.myshopify.com/p...oped-dirt-bike
    • Max Power: 4000 Watts
    • Max Current: 95 Amps
    • Max Volts: 4-13S
    • Max Torque: 9Nm
    • Motor Resistance: 0.05Ohm
    • Recommend ESC:VESC4&VESC6(3-12S )
    • Weight: 1100g
    • The motor length:84mm
    • The motor diameter: 63mm
    • Shaft Diameter 8mm, 30mm length
    It is quite possible that such a motor will be powerful enough to use the bike every day. But such frequent use will quickly turn the battery into scrap metal, so it's worth choosing a more powerful motor. I can tell you another way which was very effective for me. After I ran out of lockdown, I'm not used to the car at all, and I still travel only on my bike. I use it every day and quite often because I need to go to work, the store, and friends. It's for these reasons I had to look for something more potent than the average motor. I did it, so you should also take a look at this option.
      If it smells like
