Where and how locate battery
    My first project for and ebike its a bafang mid drive in a orange 5 frame. The shock its horizontal so Im thinking to put the battery under down tube and low, near mid motor. How I could fasten/secure the battery to the frame and be sure wheel dont touch battery ? Thanks
    You probably need to make a cardboard/paper template of the exact battery and housing you intend to use. Collapse the suspension fork by removing all the air or the coil spring. While collapsed, position your template in places along the downtube to see the maximum upper position that you can locate the battery/housing. Give yourself some fudge factor to be safe. You can add your own rivet nuts where the best location is determined if any factory rivet nuts are not in an ideal location.
