I just thought this deserves a thread. The old 26" MTBs with 3x drives are good bikes for conversion. 29ers came out in that era also.
There are a lot of new parts becoming available for this. Wide range cassettes, and matching derailers with clutches and capacity up to 50t. Shimano and SRAM have moved on to 1x 11-12 speed stuff, so this is mostly 2nd tier brands. Sunrace, Microshift and Box to name a few. Some are Shimano compatible, others are not. Shifter and even chains can be specific to each brand. Then there are the hacks to make the old stuff work. In my own case 8 speed Rapid Rise low normal derailer with a Gripshift and 11-40 cassette. Maybe some secret part numbers? Experiment that did or didn't work out? What the hell is a direct mount derailer?
My parts list.
Surly 50T Stainless Steel chainring on BBSHD 130mm spider. The Surly ring is 1 speed and 8 speed width. Known to be tight on 9 speed chain until broken in.
Roller chain guide off of the seat tube. Li'l Chap bracket drilled out for longer 8mm bolt to reach. Blackspire roller.
The roller guide got seriously upgrated during the "zip tie mod". Now it a 15t Terra Cycle recumbent idler. Both mods game changers for this old bike.
Wippermann 8SE chain $$. No Quick link. Riveted with a Rohloff Revolver chain tool. $$$
Sunrace 11-40T 8 speed cassette.
Updated to custom 11-12-13-15-18-22-28-36 cassette Full power in all 8 gears now.
Shimano XTR GS (mid cage) Rapid Rise derailer. RD M960. 9speed part, but no 9 speed Rapid Rise shifters exist.
Welded up extended derailer hanger. Cut 2 Wheelsmith 6016 hangers 2/3 long and had it welded with 6016 rod. LBS guys look at it funny, but it can be bent back into alignment. You can buy an extender online if you prefer. Broke the welded hanger, stock hanger with 11-36t cassette
Shimano RS-SL40 *8 speed Rapid Rise Revoshifter (Twist shift). You probably won't find one in the US.
I suppose I should mention the front freewheel zip tie mod, and 15trecumbent idler for chain management I've added since starting this thread.
Sunrace- Tends to be Shimano compatible.
https://sunrace.com/category/product...?speed=9-speed
Microshift- Shifters and derailesr can have their own ratios for cable pull.
Box Prime 9 (there is an 8 speed e bike option) Does their own thing. Probably best as a groupset. BMX DH background.
There is a SRAM EX1 8 speed E bike groupset. Too high end for me, maybe for these old bikes too.
My parts list.
