Hi, I'm new to this forum. As I've been planning out my first ebike conversion, I came across the Di2 versions of Shimano's internally geared hubs (e.g. SG-S7051-8, but there are others). From what I've gathered so far, there are some advantages worth considering over the cable shifting versions. However, I have yet to find a documented ebike build using a Di2 hub. Discussion about this system seems pretty sparse in general, really.
The main benefits I see are:
- less (or no) adjustment necessary, which reduces the chance of damaging the hub mechanism from incomplete shifts
- the convenience of fast and consistent shifts
- possibly more options for the shifter to accommodate handlebar types and rider preferences
- cost is a little higher than cable shifting
- if the Di2 motor stops working, you can't shift manually
- you have to charge another battery
- maybe the Di2 motor limits the cog options for adjusting the chainline in some scenarios
