Bike Chain advice
    Bike Chain advice
    I recently had a issue with my E-Bike . I just completed a long 20 mile ride and was just a few blocks from home when I hit the throttle from a dead stop , and found myself on my rear end . OUCH !
    The chain came off the front chain ring and wrapped itself in such a way , that is was logged between the chain ring and the frame .
    Thankfully I was close to home . I did a careful inspection . The chain was nasty , and I noticed that the clearance between the BBHD hub and frame was so close I could not see light , so I annded a 2mm shim . Lubed the chain , and went for a test drive . Better but I do notice I can hear the shifts.
    I uninstalled the chain and noticed a couple of links that were very slightly bent .
    So I trashed that chain , a KCM-8 , and installed a KCM -E8 . . These are supposed to be E-Bike Chains , and thankfully I had one on hand .
    So after doing some research on bike chains , even KCM , chains , I see that leaving the factory lucubration is not a good idea . Its sticky and attracts dirt like a magnet ! I just did not know that before.
    So I scrubbed off clean the factory lube , and oiled it with some synthetic chain lube . That made a profound difference . I can;t even hear the shifts anymore !
    Here is a official vid from KCM
    hopes this helps someone ! :) https://www.youtube.com/watch?v=wgYX3OVWbCM
    As far as KCM-8 chain VS KCM E-8 longevity ? We will see. Anyone else have experience with the KCM E-8 ?
