POOP Stinks and it smells like MONEY! I held my machine shop in my hands and and went CAREFULLY 0.5mm at a time with Carbide burr and 2" sander till it fit and NO MORE. See Reverend Iggy thread. U CAN DOO IT!
Found! A way to mount BBS02 or BBSHD to old fashioned American or BMX style BB!
Actually my motor would have fit without the offset adaptor IF the bottom bracket were made from steel. That little extra thickness that aluminum requires was just a silly millimeter too much. "TTGG", yours might just fit too because yours looks like thin steel.
Thanks, very helpful, yes comparing pictures my steel BB easily looks much thinner than yours and Velodrome's. If I go this route I will probably just buy the stock adapter then see if bbshd [which I don't have yet] fits. I might have bought one by now but learning that you can't use a rear coaster brake was a curve ball, my rear dropouts are 110mm and I was wanting to avoid spreading them for a fancy new hub. I have nice old 3 speed/coaster hub, Bendix Torpedo. I found some bolt on ideas for mounting rear caliper brakes though.
Originally posted by Velodrome View Posttt. The chain stays wern't the problem. Its the distance center of the Ashtabula BB / BBSHD or what ever drive shaft ,and the motor case exterior. 1.5mm more distance from drive shaft center to motor case exterior and this would not be an issue. but : learning more and seeing the problem in the flesh as it were. I do not think ANY frame with an American BB will work with these kits. Unless modified OR with an Ashtabula offset BB solution like Optimus found. Honestly, The things Optimus found are a great solution IF they hold still and behave themselves.
Machined some stock to BB inside diameter, then machined hole so BBSHD would pass through it, 1/4" offset from center. Can't recall exact dimensions at this point, I have them wrote down in shop and I'm out of town till this weekend. I have a 68mm BB. BTW my first attempt made a nice paper weight. See attached picture below. I will be working on an aluminum option next. If there was a big enough demand I might make more, but they are time consuming and don't know if many would want to pay for that. Message me if you're interested. Good luck with your build !!!
Originally posted by OptimusPrime View PostActually my motor would have fit without the offset adaptor IF the bottom bracket were made from steel. That little extra thickness that aluminum requires was just a silly millimeter too much. "TTGG", yours might just fit too because yours looks like thin steel.
Originally posted by Velodrome View PostUmmm NOPE. My Felt frame is steel. Not aluminum. Still was nowhere near getting it to fit without radical mods or the things Optimus found and SPORTY made
EDIT: I measured, my prime candidate for conversion BB outside diameter is 56mm, the orange one in the pics [I have several of these bikes] is 57mm. Velodrome could I possibly get a measurement on yours and thoughts on fit if it is larger, thanks!3 PhotosLast edited by ttgg; 03-10-2017, 11:47 AM.
Originally posted by OptimusPrime View PostCheck my quick figures but if the BB is 56, and the BBSO has a 12mm clearance between the axle housing and the motor housing, AND the BBSO axle is 34mm. Then 28mm minus 17mm equals 11mm and you have 1 mm more than you need!!! IT FITS!!!
Looking ahead, for my other bike with 57mm leaving exact snug fit, maybe not ideal but I had thought about that earlier. In context of de-coupling the motor housing from the frame so it doesn't transfer or amplify noise and vibrations would be desirable.
With Velodrome having blazed the trail on the grinding approach, perhaps a few strokes with a coarse file would clear things up if it was just touching. If I'm seeing it correctly one thing that bothered me about grinding was it appears one of the case bolt heads and its passageway was slimmed down.
The amount of metal that needs to get gone is very small. I took perhaps a bit too mush as I had a fair bit of wiggle room once assembled not the glove tight fit I was seeking. Proper offsets for Ashtabula BB's would be the perfect answer. Some like me tend to get carried away and take too much metal. I take after my Dad. When trimming a tree he would; without fail end up with a nub on the ground and he'd send me to get a shovel... :) Heres where the offending bit of aluminum needs to be taken away if your going the grinder route.2 PhotosLast edited by Velodrome; 03-10-2017, 03:28 PM.
Thanks Velodrome, much appreciated. According to OptimusPrime calculations above, I may have 1mm clearance with my 56mm OD bottom bracket. If you can get to it and have a caliper could you possibly measure your bottom bracket OD? I'm guessing on a modern cruiser bike the steel might be a little thicker than mine. If yours is greater than 57mm or so I'd say I'm golden, especially as you say the fit was almost there on yours. thanks!
I have found a couple more resources, or one new and one expanding on what OptimusPrime found. In case anyone checks in on our mini knowledge base we've started here:
This guy crafted asymmetric end caps like the guy from Latvia, and his as well were for the TSDZ2:
https://endless-sphere.com/forums/vi...tsdz2#p1207681
And here is the guy from Latvia posting about his end cap work on a mega TSDZ2 thread:
https://endless-sphere.com/forums/vi...t=225#p1256529
