Hello I have a gary fisher 29er bike that i recently converted with the bbso2. Everything fit great but because the BBSO2 was designed specifically for 68mm bottom bracket and mine was 71mm, i had to find longer bolts and put spacers to make it fit. Now that's perfectly fine but I want to replace the 46t ring with a lekkie bling ring however lekkie goes a little bit deeper than the original bafang 46t ring. The problem i'm going to have is that right now it's already too close to the frame and if i put spacers between the motor and bottom bracket i will have to compensate for it on the mounting side which already has a gap that i filled with 3 washers on each bolt. Any suggestions on what i can do would be greatly appreciated. The original ring isn't that bad but it's too large and the chain would sometimes fall off. That's a big reason why i want to replace it with the lekkie one. I'll post couple pictures to show exactly what the problem is. Thanks for all the help
71mm bottom bracket and BBSO2 problem with mounting bolts
which one is that? I'm sorry i'm brand new to this and i'm in the learning stage still. if you could link me to that one i would appreciate it. Is it the mighty mini you're talking about? I saw that on luna's site. Or i can just put a chain guide on the current one and keep that one. It's not so bad. Anyway i appreciate your help. Thanks againLast edited by intramorph; 11-01-2017, 08:30 AM.
- Likes 1
Originally posted by intramorph View Postwhich one is that? I'm sorry i'm brand new to this and i'm in the learning stage still. if you could link me to that one i would appreciate it. Is it the mighty mini you're talking about? I saw that on luna's site. Or i can just put a chain guide on the current one and keep that one. It's not so bad. Anyway i appreciate your help. Thanks againLast edited by Poco Askew; 11-01-2017, 09:34 AM.
