Hello,
New to ebikes and failing early and fast at basic electrical things. I was using my volt meter and absolutely fried the Anderson connector when I connected the black to the red coming off the battery cradle. If I was testing whether I can melt the connector and my volt meter I have succeeded.
What I was trying to do before ruining the connector was trying to wire four 12v lights for my evening commute. I pulled off the plastic cover on the battery cradle and soldered on wires coming from the black and red sides. I was treating black as power and red as ground but I may have absolutely no idea what I'm doing at all since my only experience is with AC current. Anyway, what I did was take black from the battery and run it to a on/off switch, took that and ran it through the four lights in series, and then returned it to the red wire side of the battery cradle.
That did not work. Should that work in theory? That didn't result in a sparkball like when I started trying to check my work, but may have made a little noise when I first flipped the lights on switch (or may be just when I put the battery on, not sure). The battery and everything still work fine after the big spark. I ended up soldering the battery cradle wires directly to the BBS02 wires but have some xt-60 connectors ordered and will fix my mess when they arrive.
Any help/criticism/pointing and laughing greatly appreciated.
Thank you.
William
Thank you.
William
