I recently installed a bbso2 kit on my bike and i've seen videos where they put shims to make a little space between the motor and the bike frame. On my bike it touches the frame but i see absolutely no problem with running it this way. I guess my question is: Should I get the shims/spacers and remount the motor with those or can I just leave it touching because there's no moving parts that get obstructed by that. in other words I see no reason for the shims unless someone can explain why i need them. Another thing is that my bottom bracket is 71mm and there's already 3mm space that i have to accommodate for on the mounting side of the motor so i had to get longer bolts with spacers/washers to fill in that 3mm space. My concern is that if i put more shims to move the motor even further away i'm gonna have problems on the mounting side. I hope i'm not killing the motor because it's touching the frame a little bit =)
BBSO2 touching the frame of my bike
As far as I know, the usual reason people shim their motor is to allow the motor or chainring to clear the frame, or possibly to improve their chainline. If everything works, shimming is not needed or even desirable. If it bolts up without shimming, but you want to improve the chainline, I'd try to correct it by using a different chainring, or by shimming just the ring - not the motor. YMMV.
- Likes 1
Originally posted by Poco Askew View PostAs far as I know, the usual reason people shim their motor is to allow the motor or chainring to clear the frame, or possibly to improve their chainline. If everything works, shimming is not needed or even desirable. If it bolts up without shimming, but you want to improve the chainline, I'd try to correct it by using a different chainring, or by shimming just the ring - not the motor. YMMV.
Thanks man
Sorry - I misread your post. Since the motor IS hitting the frame, I would probably shim it away a slightly. With frame flex, I'd be concerned about putting force on the motor housing. Dunno...
- Likes 1
Originally posted by Poco Askew View PostSorry - I misread your post. Since the motor IS hitting the frame, I would probably shim it away a slightly. With frame flex, I'd be concerned about putting force on the motor housing. Dunno...
Another question will these fit the bbso2 because they're maketed for the bbshd https://lunacycle.com/parts/bafang-p...ting-4-pieces/
Thanks PocoLast edited by intramorph; 11-14-2017, 12:19 AM.
Epoxy putty makes a nice fitting spacer between motor and frame. Tape or wax frame so it won't stick. Form to fit. Sugru is rubbery if you prefer soft, but rigid is better IMO.Last edited by JPLabs; 12-06-2017, 02:02 PM.Fabrication is fun! Build something today. Show someone. Let them help. Inspire and share. Spread the desire.
